Spektrum DX18 programming
Old 03-28-2020, 08:53 AM
dtrawford
Default Spektrum DX18 programming
Have a steerable nose wheel on a separate auxiliary channel which is linked via a mix in my tx.
i want to set up so that when the retracts are up the nose wheel steering is immobilised when rudder is being used in flight.
I have assigned the retract switch which is B to be active in the down position .I cannot get the rudder to nose wheel mix to be active on the monitor screen . Any ideas out there?
Old 03-28-2020, 10:09 AM
BarracudaHockey
BarracudaHockey's Avatar
Can you export and post your SPM file?
Old 03-28-2020, 10:53 AM
dtrawford
Not that clever. How would I do that?
Can somebody just go through the stages that has done this?
Old 03-28-2020, 12:49 PM
BarracudaHockey
LOL ok we will do it this way.
We will assume Aux 4 for your nose steering and Switch A for the gear switch. Switch B is 3 position and that doesn't really make sense for landing gear.
Go into System Setup
Channel Assign then scroll to Next which will take you to input select
Scroll to Aux4 and high light it, move the LTR button to assign the input for Aux 4 to LTrA
Go back to the main screen then go into the Mixing screen
Set up a Normal mix
Rudder as the Master, Aux 4 as the slave
I use 70% both ways for the rate, set these to how much steering you want with rudder input
Trim INH
Switch A
0 is highlighted dark (selected or mix active)
1 is light (not highlighted and the mix inactive)
The end result is when the A switch, or my gear switch is down the switch is towards the back of the radio (away) which is 0, the mix is active and the nose wheel steering is active
When switch A is pulled back the servo centers and nose steering is disabled and the gear retracts
Also, instead of fooling with sub trim or rudder trim, you can us the LTr button to trim the nose steering on the fly without it being tied to a knob or something that can get moved by mistake.
Old 03-28-2020, 01:46 PM
dtrawford
Worked and great thank you very much!
Old 03-28-2020, 02:00 PM
BarracudaHockey
My pleasure!
Old 03-28-2020, 04:16 PM
dtrawford
I looked at the link to your flying field and am very envious of that fantastic runway.
The JMA use old military airfields in the U.K. generally
Old 03-28-2020, 04:25 PM
BarracudaHockey
Oh thanks! Yea, we have a great facility, bathrooms, wifi, 2 paved runways, we are very lucky and have a great relationship with the city.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
