Are there any inexpensive transmitters that work for a lot of different receivers?
#51
Have you looked into the Real Good Guide yet? There's a thread about it and advertisements on RCG. The author does a great job of explaining all kinds of things there, and has a big index that lets you find things by "how do I?" kind of searching.
Andy
Andy
bisco (10-15-2020)
#52
i will search for it today.
#53
Bisco, I'm new on this forum and apparently I'm not allowed to post URLs until I have posted ten times, but if you do a Google Search for "rathergoodguides" you'll find it under the Documents section.
I specifically wrote the Rather Good Guide® for both newcomers and experienced pilots -- there's a free 77 page sample that you might want to download first -- it has five pages of each of the main sections -- plus the table of contents, the table of figures, and the index so you can get a good sense of what's covered, how it's covered, and whether or not it's what you need.
Thanks for the kind words, AndyK!
Cheers
Andy #3
Cheers
Andy #3
bisco (10-15-2020)
#54
Cheers
Andy #3
Cheers
Andy #3
#55
bisco, here ya go!! Check it out, it's good stuff! I'll be picking up a full copy myself very soon... I've been meaning to grab one... this is incentive now though.
Don't worry that it mentions the DX9.. it's very worthy of the whole DX family of transmitters... you'll learn more from that then we could write in this thread...
Spektrum DX9 Guide
Spektrum DX9 Guide
bisco (10-15-2020)
#56
thanks all!
i will read the promo pages and hopefully it will be just what the doctor ordered.
#57
Cheers
Andy #3
#58
hi all, i just wanted everyone to know i got my aeroscout programmed, bound and had the maiden flight.
beautiful airplane. while i don't understand why i'm doing what i'm doing, i am at least able to follow the directions.
thank you!
thank you!
#60
hi folks,
a couple of questions:
how do i find out what version software i currently have?
do i need a pc, or will the download work on a mac book pro?
more questions to follow
#61
For a transmitter, when you turn it off it shows in the corner.
For a receiver, the Windows PC Programmer software using the SPMA3065 cable is the tool. PC or Mac, so long as you're running Windows.
You can also use a mobile app with either a Bluetooth adapter (BT1000) or SPMA3065 cable if your phone supports OTG.
Easy answer - PC and SPMA3065.
Andy
Andy
bisco (10-17-2020)
#62
Andy
Andy
#63
on a good note, i checked 'my products' at the spectrum website and my tx is registered.
bisco (10-17-2020)
#65
i flew my aeroscout tonight for the second time. just beautiful. it was so calm, i thought i would try intermediate. no change though. so i tried expert, same thing.
i'm going to have to relook at my set up
#67
hmm... you might need the update to get everything in good sync..., v2.0 was probably quite a while ago. Once you get your windows working and get the file on the SD card, you can right to the newest version of airware and load it. You don't have to load every version in between.
Do you know what receivers are in your planes? I'm glad it's now working a bit better for you.
#68
safe was on in all 3 modes. i could not bank the plane more than 30 degrees or so, and no looping.
#69
someone told me to check the switch. sure enough, sport cub S2 uses switch D, and aeroscout uses switch B. i set it up. but didn't realize they would stipulate a different switch.
