Drop-in Replacement For ACE 342 Standard Servo
Old 03-24-2022, 07:59 AM
Crazy Legs
Default Drop-in Replacement For ACE 342 Standard Servo
I have several airplanes that used the ACE 342 Standard Servos for all surfaces when I was actively flying about 13 years ago. At this point I would like to switch over to Spectrum's Receivers and new servos that would work with the Spectrum Receiver that can be a drop-in replacement for the ACE 342 Standard Servos (so I don't have to re-drill my servo mounting rails). It looks like the HiTech Standard Servos are very similar, but I'm not sure because I don't have the exact mounting dimensions for the ACE Standard Servos. Does anyone on this forum know if any particular model servo would be a drop-in replacement AND work with the Spectrum Receivers?
Thanks!
Mike D'Amico
Old 04-20-2022, 09:13 AM
Crazy Legs
I'm going to answer my own question: I've determined that the JR NES-537 is an exact replacement for the ACE 342 servo. EVERYTHING is exactly the same accept for the JR plug instead of the ACE Deans plug.
