Does Light on Spectrum Satellite Antenna Indicate Binding?
FL
I'm using a Satellite Antenna with my Spectrum AR7000 receiver. Since I've got a 60 Glow Engine, and it vibrates the airframe, I mounted the receiver in foam like the instructions suggest, however, that means I can't see the Orange light inside that receiver that indicates that the Receiver has been bound to the Transmitter. Since the Satellite Antenna also has a light on it, do any of you know if that light also reflects the same information as the one on the AR7000 Receiver? If that's the case then I have nothing to worry about since I can easily see that light.
