Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > RC Radios, Transmitters, Receivers, Servos, gyros
Reload this Page >
Is A Metal Cable For Throttle OK Using Du-Bro E/Z Connector
Old 04-20-2022, 11:50 AM
Crazy Legs
Default Is A Metal Cable For Throttle OK Using Du-Bro E/Z Connector
I have an old OS Max H60F Gold Head that has a cable type of push rod that is connected to it's carburetor using an Du-Bro Kwik-Grip E/Z Connector. So the cable is metal and the connector is metal. Is there anything wrong with doing this at this point in time? Use to be a no-no when on 72 MHz radios and earlier. Please see photo and let me know if it's OK to us as shown. FYI, I'm using a Spectrum AR7000 receiver. Thank you.
This is the method used to connect throttle cable to carburetor.
Old 04-20-2022, 03:17 PM
init4fun
init4fun's Avatar
The only problems I ever heard of with metal throttle cables was with gasoline (spark ignition) engines causing RFI. since your engine is glow you'll be fine with it as is...
Old 04-21-2022, 03:44 AM
rgburrill
rgburrill's Avatar
I used a metal pushrod with a metal clevis once and it was very bad. The pushrod rubbed against the firewall and created all sorts of electronic noise. Changed to a nylon clevis and the problem went away. In your case the metal seems to be protected from the firewall by the nylon sleeve. I think you are ok, at least to try it.
