DX9 Black Edition Transmitter Sticks
Old 06-23-2022, 04:18 PM
mrcoolpop
Default DX9 Black Edition Transmitter Sticks
I have the Spektrum DX9 Black Edition transmitter. I attempted to adjust my right stick (ailerons/elevator) stick and it came completely out of the slot. I noticed that it has small grooves and it pushed it back into the slots and it functions correctly. However, is this normal and has anyone else had the same problem?
Old 06-23-2022, 04:25 PM
mrcoolpop
Old 06-27-2022, 06:12 AM
AndyKunz
I don't know of anybody else who has had the same problem. Those splines are a pretty tight fit.
The gimbal can be replaced if you like. Contact our Service folks for that. If you don't want to go there, you could try using a small dot of thick plastic glue or nail polish (they are styrene) on the spline and then inserting it and allowing it to cure. Don't use acetone (lacquer thinner) or nail polish remover or CA, as it will run into places it shouldn't go.
Andy
Old 07-08-2022, 10:03 AM
2W0EPI
This inexcusable from Spektrum, bad news, quality problems.
