quality standard servos?
Hi gents,
I have been away from the hobby for a while - any recommendations for good quality standard servos in 10kg range?
thanks,
Artto
thanks,
Artto
daveopam (02-04-2023)
KST makes some nice mid-priced servos. You can find them several places, including www.buddyrc.com
Here is one possibility that Buddy RC has listed for $65.00 that might meet your needs on 6 volts:
KST DS1509MG High Speed High Torque Low Profile Digital Servo, 0.07s 177oz @7.4V, a great choice of steering servo for RC cars.
The KST DS1509MG offers a wide voltage range of 4.8 - 7.4 Volt and is therefore universally applicable due to the low profile construction.
High positioning speed and the torque of up to 177oz.inch at 7.4 V allow the use of the servo in both aircraft models and the RC cars.
Specifications:
Brand: KST
Item model: DS1509MG
Material: Metal
Signal: Digital
Operating voltage: DC 4.8-7.4V
Connector wire: About 205mm
Operating speed: 0.07sec / 60°@ 7.4V; 0.08 sec / 60° @ 6.0V; 0.10 sec / 60° @ 4.8V
Stall torque: 12.8kg.cm @ 7.4V; 10.7kg.cm @ 6.0V; 8.5kg.cm @ 4.8V
Working frequency: 1520us/333Hz, 900us-2100us
Motor type: Coreless motor
Bearing type: 2BB
Programmable: YES
Item size: 40.5*20*25.4mm
Item weight: 55g (wires included)
Specifications:
Brand: KST
Material: Metal
Signal: Digital
Bearing type: 2BB
Programmable: YES
