Servo reversing problem
Old 04-18-2023, 07:51 AM
88lover
Default Servo reversing problem
Hi. I am building a model battleship and have put one servo on each main gun turret. 4 in all. I have connected all the servos via a 4 into 1 lead. Everything works fine except 2 turrets turn left and the other 2 turn right and vice versa. I connected a servo reverser to 2 of the servos but only one works and the other 3 don't function. Any ideas please
Old 04-19-2023, 04:24 AM
AndyKunz
Any reason not to put them on separate channels?
You probably have signal level problems, or bad Ys. Make sure your Ys are all good first - actually, you want a 3-way Y and a 2-way.
For signal levels, boost the output using a boost such as SPMCP. A fanout of 4 is a pretty hefty load for a single port. I would put one directly into the receiver - this will supply the 2 servos plus the reverser. Then put one on the output of the reverser so it feeds both of the other two.
Andy
Old 04-19-2023, 04:45 AM
88lover
Default Servo reverse
Thanks for your reply. It was my fault for not checking the rotation when I built it all. I will just have to accept the front guns turning in a different direction to the rear ones. The servo reversers looked at first glance to be my answer.
Old 04-24-2023, 05:21 PM
pkoury
My Feedback: (7)
What radio are you using? Does the TX allow mixing and reversing? If so and you have enough channels can you mix the opposite turret Y harness to correct rotation turret y harness. You would then be able to reverse the mixed channel in the TX.
Old 04-24-2023, 10:09 PM
88lover
Thanks for that. I can change my TX and see if I can mix as you described.
Old 04-27-2023, 07:37 AM
daveopam
My Feedback: (9)
daveopam's Avatar
If your servos happen to be digital Hitter you can buy a programmer and reverse them.
David
