Futaba 12FG with modern electric planes throttle cut how?
Hey guys, I have a Futaba 12FG and I was wondering if anyone has successfully programmed the radio to cut the throttle off for and electric plane. this is one of the only things I cant seem to get working right. partially because Futaba programming is convoluted and I have a hard time understanding their way of thinking.
I have a bit of a back story that may need to be heard. I have successfully used a lemon RX DSMP DIY module for legacy transmitters so I can use my existing Spektrum systems installed in my planes. via the trainer port. so the radio has to be operated in trainer mode. Trainer mode might be why I can't seem to get this to work. however, I am able to bind to Spektrum receivers and program the switches to work with SAFE modes. beginner, intermediate and off. everything works on my apprentice STS except the throttle cut. anyone think they might know how to help me?
I Found a review of this radio where the guy had found several programming features of the radio he couldnt get to work right either.
i have a basic sig kadet trainer glow powered and i cant get the throttle cut to work with it which its intended. When i flip the switch to cut the engine, it operates the servo the wrong direction. Theres no setting to reverse it.
Im giving up on this radio and buying something modern. 08 doesn't seem all that long ago but this radio is far behind. Seems like an experiment radio that was full of bugs and futaba quickly abandoned it
My Feedback: (243)
Nothing wrong with the Futaba 12FG, certainly not an experimental rig as you suggest.
Futaba designs equipment to work properly with it's accessories, not those of other manufacturers. Using other equipment invites conflicts as you have learned. Generally the channel mapping differs from Futaba so when programming certain functions it may or may not work due to a missing channel link.
Spektrum, Lemon and a host of knockoffs all operate on the original JR systems channel mapping and mixing functions although well updated over the years. Aftermarket manufacturers follow that pattern to insure compatibility as it is not as complex as Futaba.
Futaba has worked with some high end aftermarket people to integrate some equipment into their data stream, but not many.
Futaba gear works best with Futaba. And Futaba generally does not give a hoot if a lot of marketplace, good or crappy equipment, doesn't work well.
If one wants to fly Spektrum, or Spektrum related products, buy a Spektrum transmitter. I own both systems so I don't have to fiddle with incompatibilities. Both systems work fine when staying within brand.
Use your Futaba 12FG for it's intended purpose. It is a reliable, robust transmitter although missing many of today's desired bells and whistles. most of which are never used anyway.
Good luck and enjoy.
