Spektrum Flap question
I am a newbie so not fully versed on all this. I have read a ton of posts, but want to ask here. Is there any way to configure flaps with a Spektrum DX-8 on one channel? I have a 7 channel receiver I woudl like to use on a gas Cub, however i run out of channels for the flaps.
I have Throttle, kill switch, power, ailerons, rudder and elevator and want put flaps on the other, but they move opposite directions. Is there any way of doing this except with a reversing Y connection? From what I gather the answer is no, but wanted to ask a direct question here
TIA
TIA
You listed 6 functions for a 7-channel receiver. So maybe you have dual ailerons set up?
If so, then you could put them on a Y lead, change the wing type to 1 Ail/1 Flap, and that would give you flaps on channel 6.
Or you could put in an 8 channel receiver.
Andy
Andy
Andy, Thank you for the reply. I have 6 functions listed plus the flaps which is the 7th. But I need two channels for the flaps so I am one short.
For my edification..I tried them on a Y lead but they acted like ailerons and moved in opposite directions. To make sure I understand you I need to change the wing type in the transmistter right?
Speaking of an 8 channel....this actually is a Spektrum 8000 but on Aux 3 two pins are missing. Is that repairable? That would also be an option if so.
It would be a lot easier to help if you exported the model and attached the SPM file here.
If the flaps are moving in opposite directions, then 2 channels is the correct way to solve that. Does that now mean you need 9 channels?
Yes, the receiver can be fixed.
Andy
Andy
Thanks Andy. Unfortunately, I can't export right now. I had to send my TX in for repair and either removed the flash card and misplaced it or left it in. Either way I don't have one.....but you told me what I need to know...two channels. I will go that way. 8 channels will suffice.
I will contact customer support to get that RX repaired...in the meantime I do have a 9 I can use
Or you simply rotate one of the flap servos 180 degree in the servo bay. It takes a little of old school modeling work to accommodate the servo in its new position but it surely works.
