Flaperons
Old 11-28-2023, 07:19 PM
Default Flaperons
Can someone give me a quick tutorial how to set up flaperons on a Conscendo Advanced glider? I'll be using a new Spek DX-6-E and would like to use the supplied AR636 Rx, or a Lemon 6 ch DSMX capable Rx. If the AS3X must be disabled, no problem as I rarely use it anyway. It has no SAFE system. New to Spektrum and I am graduating to the DX6E from an old school DX5. Thanks for your time and assistance! Bill
Old 11-29-2023, 05:47 AM
Clear out any programming in the AR636 using the Programmer app on your PC. This will make it a "dumb" standard type receiver.
Plug the right aileron servo into channel 2 (AILE) and the left aileron into channel 6 (AUX1).
On the DX6e, create your model. Change the wing type to Flaperon.
Bind to your receiver.
Now the ailerons will respond to roll from the stick.
Go to the Flap System screen and set everything up there using a switch (usually D) to control the positions you want the surfaces to assume.
Andy
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
