Change Cox 3-1 machine frequency
I recently purchase 2 of these "Magic Machine" 3-1 toys for my 2 boys. Since Dad flys real planes, I thought a toy like this would be perfect to introduce them to flight, as well as electronics.
When the two boxes arrived, i found that both are on the same freq. No biggie, I purchased a set of RC crystals for channel 3, both toys are channel 4 now. Since I have a fair amount of experiance with souldering, I figured I could swap out the crystals in one of the toys, and they could play at the same time.
Well, the Tx crystal was a sinch to swap out. However, i pulled the circuit board from the toy and do not see a Rx crystal anywhere on the board. a few resistors, diodes, antenna, and an IC which reads RX-2B J3B81. The board is a HY-009c.
Anybody have a schematic for this, or can give some advise?
Thanx!!
Kevin
Thanx!!
Kevin
CA
RE: Change Cox 3-1 machine frequency
The only way to effectively fly two of those models at the same time is to have one on 27Mhz and the other on 49Mhz. Sadly, moving a 27Mhz rig to 49Mhz (and vice versa)would require substantial modifications to the Tx and Rx.
OK, now i have 2 other RC planes, one is channel 6, one is channel 5, the 3-in-1 toy is channel 4, and they all work corretly, around each other, with seemingly no interferance between each other.
So, it makes sense if i change the second unit to a channel 3 devise, it would work. What about completey changing out the receiver board with a cheap-ohh rc plane board that is channel 3?
Kevin
Kevin
CA
That is interesting. What are the frequencies marked on each Tx Xtal?
The RX-2B IC's operating frequency is set by the coil near the antenna. The coil's slug must be adjusted with a non-metallic wand. Be careful with the adjustment -- make sure the Rx is stable over all operating temperatures and voltages after you are done.
More info on the RX-2B can be found on my Micro-Size R/C Plane web page: http://www.rc-cam.com/microszr.htm
RC-CAM
RC-CAM
