Help with extremely weird range check
MN
I have a basic futaba skysport radio with a basic 127...7channes rx. I have made very sure to route the antenna as far away from servo wires as possible. With the wing attached and the radio antenna about 2 to 3 inches extended I can only get about 20 feet away before the servos start glitching. The strange part is with the aileron servos attached to the rx while the wing is unattached and sitting under the plane, I can walk away for days and no glitching. I made sure to route the rx antenna out of the fuse right away and have tried pinning it to the wing tip, the vert stab and the tail wheel but all with the same result which is wing attached range = bad....wing not attached range = good....Also... I did try a range check with the radio fully extended and naturally I could go about 1/4 to half a mile with no problem. I am just wondering if I am crazy or does this kind of thing happen a lot?
TX
RE: Help with extremely weird range check
Mike, when you pin the antenna at the end of the wing make sure all pins are plastic or use a rubber band to hold the antenna.(do not use any metal pins touching the antenna.) Mike also when you range check your radio's antenna is down, do a forty foot range check.
