9CAF
OR
9CAF
We just got a Futaba 9CAF Computer Radio and eveyrthing works fine on our U-Can-Do .60 size but the left elevator does not move, the right elevator is fine it is fully functional and works perfectly, i would like any and all suggestions on this subject
thank you
thank you
IL
RE: 9CAF
Yuruki, assuming you are using the ailevator functions, plug the servos into 2 and 8, and then go to AILVATOR and set the mix from INH (inhibited, not usable) to ACT (active, always on).
if you are not using channels 2 and 8, you will need to use a pmix to make them work. to do so, make the MIX setting read OFF or ON, not INH (off/on will change depending on switch assignment). make the mix master = elevator, slave - (whatever channel you used for the 2nd servo), link OFF, trim ON, switch position NULL, rates +100% +100%. that will get you flying.
