Do you lub your TX antenna?
I just got a 9C and the last segment of the antenna is very tight. Every time I extend or collapse the antenna, it snap so hard and I am afraid that the antenna is coming out soon, or I am going put push it in and destory the Tx.
Any suggestion?
Any suggestion?
My Feedback: (16)
GA
RE: Do you lub your TX antenna?
I am interested in this answer as well.
My antenna squeeks when I push the antenna in.
ORIGINAL: localbuyer
Any suggestion?
Any suggestion?
It is my understanding that oil is an insulator, and therefore the thin film that will exist between segments degrades the aerials conductivity and hence its effective length. Clean an aerial with methylated spirit to keep it free of dirt and grease and oils, but don't oil it.
H
H
Moderator
My Feedback: (58)
Any suggestion?
Any suggestion?
FWIW, rajul,
Just got a 9C and its antenna extension/retraction is very smooth...
For the $$$ you spent, I suspect Futaba would replace it under warranty if it ain't right (manufacturing/QC defect). I'd give them the opportunity to say "Yes"...
Agree with HarryC about oil being an insulator (not to mention a dirt magnet!), and if I recall correctly, the Owners Manual cautions against lubricating the antenna...
HTH
Jim
HTH
Jim
There are electronic cleaners and lubricants made for electronic contacts that can be used to clean and lubricate the antenna. They do not contain "oil" that will insulate but contain conductive type lubricants. They come in spray cans and are available at electronic supply stores and Radio Shack has them also. This will help to keep good contact between the sections of the antenna and make it slide easier. Spray the antenna lightly, slide it in and out a few times and wipe off any excess.
Hi all
Get the antenna replaced if it has only been in service for a short period. As a side issue how many people replace their antennas when they get a little loose? I measure the resistance of an old extended aerial and found it varied from 12 ohms to meg ohms with the slightest movement. Replaced it with a new one for piece of mind. Does it matter?
Regards Steve
Regards Steve
