Ailevators on a switch with 9c
My Feedback: (61)
NJ
I m using 2 elevator servos and have set them up for ailevators using the prgrammed mix..What i cant figure out is how to get them assigned to a switch so I can turn them off/on..I read the manual and Futaba's faq but cant get it right. Any help would be appreciated!
RE: Ailevators on a switch with 9c
You can't put the preset ailevator function on a switch - it is active all the time. You'll have to set up two pmixes aileron-elevator and aileron-elevator2 and put them on the same switch.
My Feedback: (61)
NJ
So instead of using the pre-set program use the two mixes for the ailevators and the pre-set program for just regular elevators??
