Jr Rx Question
My Feedback: (10)
Jr Rx Question
Hello All, does Jr radios have a high & low band like futaba? I am new to Jr stuff & have a new 649 PCM Rx in the 50"s but I need it in the 30's. Will a crystal swap do the trick like it does for Hitec or no?
Thanks in advance for any help!
RE: Jr Rx Question
Yes it should work just fine...As with all crystal changes do a good rnage test of your equipment.
I have swapped crystals from the bottom of the band to the top like 20-60 with not problems at all....Just range test it good before you fly it.
Troy Newman
Team JR
Troy Newman
Team JR
