3003BB good SERVO.....comes w/ 6EXA
NC
I will be gettin a Somethin' Extra soon, well, next year, and will get to Futaba 6EXA w/ 3003BB servos to put inside it and control it. I WILL NOT be doing very serious 3d maneuvers.......but will do what I can. No high stress things. But, are the 3003's good servos to have in this particular plane. Also, one the 6EXA, how do you make it to where you can have a servo for each aileron. I'll more than likely buy another 3003 so I can have seperate servos for each wing half. Do you plug the extra 3003 in the 5th or 6th channel, or AUX........Well, I dunno.....that's why I'm asking you guys. ANY feedback would really help me. Thanks So Much.........
My Feedback: (41)
RE: 3003BB good SERVO.....comes w/ 6EXA
I have this radio. I really like it. It will be fine for that plane and what you want to do.
Use the flaperon option in the mixing. It turns channel 6 into the left aileron. Channel 1 is the right aileron. Then you can have the ailerons function as flaps at the same time they are ailerons. Pretty cool. I have two planes set up this way.
The other option is to use a "Y" connector and just connect both servos to channel 1. I personally like the flaperons.
By the way, I the radio comes with 3004's not 3003's.
Joe
Joe
NC
I"m sorry for the mistake......i could have sworn that it came w/ 3003's but I just didn't remember......thanks for the input though.............
MS
ORIGINAL: iflynething
However, the 3003's and 3004's are the same servo with the exception that the 3004's have ball bearings and the 3003's use bushings.
So while either works as a replacement for the other, get 3004's if you have a choice because of the ball bearings.
Highflight
