futaba 3pdf help
My Feedback: (13)
futaba 3pdf help
i just got a futaba 3pdf and i tried it yesterday ..the throttle works for like 10seconds and it wont respond i put in a fresh batts on the rx and tx still does the samething so i figured to take off my ofna failsafe (the old ones green rectangle) so it worked i am not sure if the problem is because of the failsafe?and also should my throttle trim be in (0) ?i misplaced my manual and i think my wife dumped it ..cuz my truck sounds like it has a high idling as if the carb is a little bit open ..can uhelp me pls
RE: futaba 3pdf help
You can download a manual for your Futaba 3PDF from:
http://www.futaba-rc.com/manuals/index.html
If the system works correctly when you disconned your OFNA failsafe unit, the you can pretty much be sure that that's the source of the difficulty.
