Budy boxing heli mode with Futaba
Old 12-21-2003, 02:42 PM
isaac
My Feedback: (19)
Default Budy boxing heli mode with Futaba
I'm trying to buddy box 9C with 8. Both radios PCM and i'm trying to have the 9 channel as the master and the 8 as the Buddy box. I know their is a function that you can set it at and the slave will have all the master setting automatically.
Please help.
Old 12-21-2003, 11:32 PM
Icebird
Icebird's Avatar
Default RE: Budy boxing heli mode with Futaba
The slave must be set to PPM or it will not work.
Jim
Old 12-22-2003, 02:30 AM
olivier
Hi,
Check the manual page 40 (note that I do not have a 9C) :
quote
TRAINER: for training novice pilots with optional trainer cord connecting 2 transmitters. The instructor has several levels of controllability.
Adjustability:
• NORM: When the TRAINER SWITCH is ON, the channel set to this mode can be
controlled by the student. The set channel is controlled according to any
programming set at the student's transmitter.
• FUNC: When the TRAINER SWITCH is ON, the channel set to this mode can be controlled
by the student, controlled according to any mixing set at the instructor's transmitter.
• OFF: The channel set to this mode cannot be controlled by the student even when the TRAINER SWITCH is ON. The set channel is controlled by the instructor only, even when the TRAINER SWITCH is ON.
• ALWAYS set the student transmitter modulation mode to PPM.
unquote
So in your case :
1) setting to "FUNC" will allow the student to use master's settings and mixings. Be sure student is using a "blank" program, where only the reverse of the servos should be set, all other mixings disabled, all servo throws to 100%.
2) set student TX to PPM-mode
Happy learnings, but use patience, Olivier
