servo grease for nylon gears?
I have heard of all kinds of types of grease, NOT to use and what should be used. Does anyone out there have a PART# for the grease used by a major servo manufactuer? (Their Product sold, by them for gears). It would last a long time and I could just order it from my LHS. ... thanks...
lownslo...
lownslo...
NY
RE: servo grease for nylon gears?
Don't waste your time, just buy generic lithium grease from a local DIY store. Just don't use too much, just a light residue on the gears themselves and put a very small blob where it's likley to be 'bumped' into the gear train at some point just from general use. The smallest tube you can buy at a store is going to last you your entire life for use as servo grease. The cap alone will hold enough for two full applications.
My Feedback: (16)
GA
Yes, it is low sulfur lithium grease. It needs to be low sulfur so that it doesn't cause a problem if it liquefies and run into the electronics.
ORIGINAL: Lynx
That lithium grease geist.
