Futaba 9C compac how to copy?
My Feedback: (16)
WY
Does anyone know the correct step by step procedure to copy model memory from one compac module to another or directly to the 9C radio?
I have looked through the manual and also looked on the Futaba web site and have not found any procedures for doing this. I would like to copy some model memories from a friends compac to my compac and I really dont want to mess anything up by doing this wrong.
Any help would be greatly appreciated.
Thanks in advance. Bob
RE: Futaba 9C compac how to copy?
The way I do mine is a little tedious but does the job. I keep all of my plane on the Campac. I have 2 9C's with 2 aftermarket Campac modules ( for back up and redundancy ). This way if something happens to my radio I still have all of my setting on the chip. With 20+ planes I don't even want to think about a memory loss. Take each plane and go to the select model screen, then just copy from the desired plane to a number high enough to be on the chip. I believe the 9C holds 8 planes, so copy from number 9 on up.
If you have any questions just PM me.
John
John
My Feedback: (16)
WY
John, thanks for the info. That is a great idea to have all planes on the compac in case something happens to your radio. I will give this a try.
Thanks again! Good flying! Bob
My Feedback: (16)
GA
What I do is have 1-8 in the radio and 9-14 are on the compac I duplicate 1-6 in 9-14. I use 7 & 8 as copies of my planes to allow others to fly them on the buddy box or for training purposes.
