JR Radio batteries?/symptoms
BC, CANADA
I just finished flying with a JR XP 783 A.We were discussing the lithium battery in radios and that they need changing after 5 years.Mine had not been done in 6 years.After my flight I turned the radio on ,only to see a scrambled display,and then the power cut out.A few minutes later I turned on again,and the same thing happened.Did my memory battery give up,or did the tx battery quit?The radio did get some sprinkles of rain on it,but it was not enough to trickle inside and cause propblems(I hope)
RE: JR Radio batteries?/symptoms
ORIGINAL: nitro wing
It would appear your tx battery quit, though you should of had a warning either a brief "Err backup" message or a "continous longbleep". I too have had similar today but the "Err Backup" message is so brief it's easily missed. Question now is how to replace and exactly where inside the TX is it located?????
The damage seems much more severe than that. Water probably shorted out something in the radio or you have a reverse polarity damage situation. Whatever the case, you ought to send it into Horizon to get it looked at. Scrambled LCD display is a symptom of CPU issues, not low memory battery. The 3V lithium memory probably does need to be changed, but this is the least of your worries. These RC airplane transmitters are not water proof.
