can i use a plane radio in my boat????
the topic bout sums it up. ive seen all sorts of diffrent radios as being surface or air but i really dont want to get a new radio for the boat im buying.
is their a legal issue or what
thanx
Tsunami
thanx
Tsunami
CA
RE: can i use a plane radio in my boat????
No.
Frequencies are assigned for "surface use" or "aircraft use" and legally, can't be interchanged.
But if you have a brand of radio that has removable requency modules (the type that are designed to be removed and replaced by the consumer), you could have a set of modules for air use and another for surface use. This does not include simply removing and replacing crystals yourself. Legally this can be done only by licensed techs.
well thanx.
guess ill have to get a new radio
hmmm......but what about ground effect craftswhat are they on,not that i could biuld one but its on the edge of plane and boat as is a hydroplane
My Feedback: (16)
GA
It depends on the transmitter. If you have one that uses crystals, then no, you cannot change it. If your unit uses modules, then yes, just get a module in the channel 61-90 range.
ORIGINAL: tsunami
thanx
Tsunami
thanx
Tsunami
ND
how about a model of a russian [link=http://www.hydrofoils.org/Egal/egal.html]ekranoplan[/link]?
IIRC, some of the russion designs could actually get several hundred feet up, although not sustainable.
looks like some guy already tried it...
http://www.rbeverley.freeserve.co.uk/
CO
I think the main reason is so that while you're running your boat on a 72mhz (air) radio you don't screw me up when i dive bomb your boat with my P51... lol Know what i mean? I would never know that you're there and while you could swim and recover your boat i'd need a scuba suit. Seriously, a plane could fall and hit someone/thing whereas you wouldn't expect lethal damages from a surface craft.
thanx for all the input, im no where near any clubs nor do i now any body that flys in my area wish somone did . well ill get new gear when the boat comes in
thanx
thanx
My Feedback: (12)
ORIGINAL: tsunami
