Antenna for micro flight
FL
I searched through this forum and read what I could find, but still have a couple questions. I'm building a small delta (not micro, but small) and there is no place to put an antenna. I though about nyrod inners in the wing, but the antenna would have to come out a wing tip and then go back in and it would still hang out.
If I hang the antenna out the back, there will be at least 2' of antenna wire trailing behind which isn't acceptable.
So I'm thinking about using a whip antenna. My question is can I install the antenna completely inside the wing with no problems? Not sure if it would be removable or a permanent part, but I can't start building until I solve the antenna dilemma.
Paul
Paul
CA
ON, CANADA
RE: Antenna for micro flight
Paul:
Been using an antenna I found on the net. I think it was under gadgets. Anyway its a little over 12 in long. You cut the antenna 4ins from the reciever, solder on a 1.5 microhenry choke coil then 8 ins. of wire. I used .020 piano wire with a small loop on the end of it. I put spade connectors on it so I could put the normal length one on if I need it. The choke part # is Miller 9230-24 . Worked so well without a glitch, three more are done this way. One is on a Pizza Box. Once I had it overhead About 500 ft with no problems. Have to keep these small planes fairly close anyway.
FL
OK, I can handle soldering, but I know jack about electronics. Who's MicroHenry and where can I buy his chokes?
ON, CANADA
I'm about in the same boat. To me, looked like a piece of wire with a little lump in it. Went to an electronics supply store and ordered it by that number. Didn't know what I was getting. There's a coloured band around it so I asked a more knowledgeable friend and he said it didn't matter which end was soldered to which end.
My problem is, if it doesn't have a spark plug I'm done.
the small FMA receivers can have the antenna cut to 18" without being detuned, just a loss in range. i've been using the old tetra single conversion FM with a 20" antenna for small planes and have never managed to lose radio contact due to the shorter range even when i'm almost OOS.
dave
dave
CO
Here is some optins from tower hobbys.
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXK820&P=7]hayes whip[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXK821&P=7]hays whip 12"[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXK822&P=7]inside antenna 18"[/link]
I hope you find this helpfull.
OH
Has anyone tried the Berg Sticky antenna available from Air Craft World? URL is here:
http://aircraft-world.com/shopexd.asp?id=2049
Looks like it would work perfect in a wing.
Keep 'em up,
Ed
Keep 'em up,
Ed
Banned
ORIGINAL: ZAGNUT
In my own tests, the M5 has just 65% the range of the Hitec 555.
So, you're probably safe if you cut the receiver antenna down for small models, but don't forget to replace it if you decide you want to use the M5 in a larger model that migth fly at greater distances.
I have to disagree with Xjet on the FMA5's range. It is extremly good, better than most standard size receivers and as good as any normal Hitec or Futaba and better than many JR's. I've used it on 1/4 scale with never a range problem as well as on many small electrics. Yes, it you cut the antenna in half, it will lose some range but will still stay in tune with no glitches.
Paul,
Here is a link to some 5" to 7" antennas that I have been using on my electric foamies. No problems with them at all.
Dan
http://radicalrc.secure-mall.com/sho...80&cart=152644
Dan
FL
Hey! Check this out! They'll be at my club this month.
Had fun at Toledo, see you in Florida at Hernando Aeromodelers April 24th, Springhill, Florida
Banned
ORIGINAL: Rodney
I emailed FMA's support just to make sure that I wasn't dealing with a dud receiver and they didn't even do me the courtesy of replying.
On that basis I my summary was that the M5 provides adequate range for most models and the S.M.A.R.T. decoding works as advertised, but that FMA's support sucks (quite an important issue when you're relying on their gear to keep your expensive model safe) and that the other receivers tested offer significantly more headroom in respect to maximum operating range.
Note that I have flown the M5 and it's worked just fine on a small model so I'm not knocking it -- just pointing out that shortening the receiver will further reduce an already lesser range.
Perhaps the unit I received was faulty -- but FMA support don't seem to care enough about that to respond to my queries, and that's a *big* worry.
Suffice to say that on the balance of evidence, I won't by buying another M5.
