throttle ratchet
Old 03-07-2004, 06:36 PM
Spaceclam
Spaceclam's Avatar
Default throttle ratchet
I have a futaba 8u and am looking to see if either futaba or some other aftermarket company makes a finer ratchet than the one that comes with the radio. the stock ratchet has only 27 steps and my plane is relatively small so little throttle differences are far more noticable. or am i just wasting my time trying to find a really obscure product.
Old 03-07-2004, 07:35 PM
Freddy418
Default RE: throttle ratchet
I'm gonna be watching this thread closely, the 8uap ratchet on mine is a pain for heli flying.
Old 03-07-2004, 08:11 PM
Spaceclam
Spaceclam's Avatar
you can take the ratchet off i know, but i am looking for a finer ratchet. it feels too woerd without resistance, and for people like you i am sure that somebody msut make something
Old 03-07-2004, 09:43 PM
Geistware
My Feedback: (16)
Why not use the point mixes and make the adjustment there?
Old 03-07-2004, 10:28 PM
Freddy418
ORIGINAL: Geistware
any instructions on how this could be done?
Old 03-08-2004, 12:16 AM
Spaceclam
Spaceclam's Avatar
what? what it want to do is make the ratchet finer so instead of having 27 clicks it might have 37 or something. no mixer will alter that. it is the size and count of the splines on the ratchet
Old 03-08-2004, 07:21 AM
CafeenMan
I have the 8UHP and bent the ratchet out so it doesn't engage at all. It can be removed, but I didn't do that because I know I would lose it. I love the way the throttle works now with no ratchet on it.
Old 03-08-2004, 08:13 AM
MajorTomski
MajorTomski's Avatar
I fly an OLD LMH 110. The ratchet on the Hitec naturally fell one click too high to hover and one click too low to settle. Bending the spring out of the way resulted in a very sloppy throttle. I put a small piece of fuel tubing over the spring so that it still presses on the ratchet teeth. this gives nice resistance and an infinitely variable throttle.
HTH
Tom
Old 03-08-2004, 09:44 AM
Charlie P.
Charlie P.'s Avatar
How about using the trim buttons? I believe there are 120 trim positions between end-points. 4X finer than the throttle clicks.
Old 03-08-2004, 10:23 AM
Spaceclam
Spaceclam's Avatar
majortomski, i like that idea. i will have to see if i can do that on the 8u. however, it would still be preferable to have simply a finer ratchet. i will try it though.
Old 03-09-2004, 01:39 PM
Warren
My Feedback: (72)
Warren's Avatar
The serations are actually on the gimbal itself, so you can't make it any finer.
Old 03-09-2004, 02:39 PM
Flypaper 2
Heatshrink tubing works well also. Don't even have to shrink it.
Old 03-09-2004, 07:38 PM
Spaceclam
Spaceclam's Avatar
rrrrgh.
Old 03-09-2004, 07:42 PM
CafeenMan
If you bend it back a small amount then it's free and if you don't like it, it will bend back to where it was.
Old 03-09-2004, 07:46 PM
Lynx
I still like the idea of replacing the ratchet with something that has a lot more tension but just touching the throttle 'ratcheter'. It won't 'click' but it won't want to move either. Isn't that what throttle ratchets are for? The ability to restrain movement? It takes X force to overcome a 'ratchet' and X force to overcome a tension, ratchets are finite, something used as a physical tension (like fuel tubeing) will provide infinite throttle placement, but be just as hard to move. It should appease everyone. Except those people that swear a throttle MUST 'click'
Old 03-09-2004, 08:19 PM
CafeenMan
Have I mentioned that my idea is free to try, requires almost no effort and I really like it?
Old 03-09-2004, 08:52 PM
Spaceclam
Spaceclam's Avatar
i have tried radios without the ratched and they feel kinda funny. good idea though. it is just my personal preferance.
Old 03-09-2004, 10:00 PM
CafeenMan
Yes, but not all radios are the same. Your choice though. Hope you find something that you like.
Old 03-09-2004, 11:24 PM
XJet
Banned
My Hitec Eclipse 7 came with an alternate piece of metal that has no indentation to catch the ratchet on the throttle gimbal. When you swap this for the standard indented item, you get a throttle with a nice friction, no ratchet, and infinite positions.
It would not be hard to do the same for other transmitters.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
