NEW 9C synth
Old 03-07-2004, 09:38 PM
3d-aholic
My Feedback: (7)
3d-aholic's Avatar
Default NEW 9C synth
Any news on the new 9C Synth from Futuba... I originally heard this was going to be out Mid-Feb or Mid-March in September. I purchased a Futuba instead of a Hitec based upon this information and starting to worry a bit. []
Old 03-08-2004, 01:19 AM
3DFanatic
Default RE: NEW 9C synth
Yeaaah... I hear ya.
Old 03-08-2004, 10:52 AM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Oh, it will come soon, just like the sun will rise. Question is how much $$
Old 03-08-2004, 11:25 AM
3d-aholic
My Feedback: (7)
3d-aholic's Avatar
ORIGINAL: rajul
Well as long as it doesn't take as long as the sunrise period on Pluto.....
Old 03-10-2004, 11:32 PM
Pimpwerx
I think a lot of people are waiting on this. I'm waiting for it before I buy my 9C. I'm getting awful impatient. PEACE.
Old 03-11-2004, 01:52 AM
Geistware
My Feedback: (16)
The module has been delayed. It should be out soon
Old 03-11-2004, 11:55 AM
nedyob
My Feedback: (67)
Witch will come first the synth. module or Christmas. I think I'll ask Santa to bring me one and wait to see what I get. More likely a lump of coal.
NEDYOB
Old 03-11-2004, 12:09 PM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
It could be a business decision by Futaba to delay. Perhaps they need to reduce the inventory of the standard module to a "safe" level before releasing the synth module, assuming the demand is good.
Old 03-11-2004, 12:59 PM
MHawker
My Feedback: (16)
MHawker's Avatar
Imagine what the market for standard modules is going to be.... CHEAP! Maybe I'll skip the synth and buy up some of the old standard ones. I'll only need a couple extra. How many channels do I fly on anyway?
..... now if I had a synth RX too?....hmmmmm
Old 03-11-2004, 10:05 PM
rjmdubois
I have a 9C for almost 2 years, using the Spectra (Hitec) module without a problem. Actually, when I range tested, the Spectra increases the range by a few feet, compared with Futaba module.
Old 03-11-2004, 10:32 PM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
ORIGINAL: rjmdubois
Are both your Futaba and Hitec modules on PCM or FM ?
Old 03-11-2004, 10:48 PM
3DFanatic
PCM is FM
Old 03-11-2004, 10:50 PM
AirBearMA
Use of the Hitec Spectra on the Futaba 9C is highly questionable and illegal by both the FCC and AMA. While you may see that it "appears" to work on your channel. What you will not see without specialized measurement equipment is the increased ajacent channel interference.
If my plane got shot down by someone using this type of setup, I would be pretty upset.
Old 03-11-2004, 11:01 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
ORIGINAL: 3DFanatic
PCM is FM
Yes and no.
PCM can send much higher frequncy information in many cases than a normal PPM (not encoded) data stream. I have seen modules that will pass non encoded data very well and completly wipe out a Futaba PCM data stream.
Old 03-11-2004, 11:08 PM
rjmdubois
I use the Spectra module on both PPM (Futaba and Hitec) receivers as well as PCM (Futaba).
Regarding the interference in other channels, we have a frequency scanner at our club and no problems detected so far. I am not sure if this FCC and AMA restriction does not have to do with marketing interest of some companies. Some years ago I used to hear that you couldn't use JR servos with Futaba receivers....
Old 03-12-2004, 12:47 AM
macgyver22
ORIGINAL: AirBearMA
Why is this illegal?? I don't think I would do it, don't like to mix-n-match certain things. Unless you can point to a specific place in the FCC regulations about using this setup (forget the AMA) I don't see where the illegality comes from . Has anyone here ever read the FCC regulation (forget the AMA - they have no authority)? My basic knowledge says that you cannot change crystals, only entire RF systems - this would seem to comply. Not saying it is a good idea, but unless you can point out the regs, it seems that deeming it illegal is a bit hasty.
Old 03-12-2004, 03:03 AM
XJet
Banned
Actually it makes sense for RF modules not to be approved when used in a transmitter for which they weren't originally designed or in which they've not be certified.
Just one of the problems is that the aerial on the Futaba transmitter may be a different length, inductance or capacitance and that could result in the RF module's output stage producing excessive off-frequency output (splatter or harmonics) -- to saly little of having a lower-than optimum RF output.
If I were going to use a Hitec Spectra mdule in a Futaba transmitter I'd want to retune it for use with that transmitter - just to be safe.
Old 03-12-2004, 10:14 AM
Geistware
My Feedback: (16)
How do you tune a multi channel module to a transmitter.
That doesn't sound right, but what do I know?
WHile the spectrum module worked well in the 8U series of transmitters, Futaba did change something in the 9C that makes it less than optimal. What I don't know but this has been discussed in the past on RCU
Old 03-12-2004, 10:18 AM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
ORIGINAL: Geistware
You don't have to. That's what the PLL circuitry is for. But I'm no expert
Old 03-12-2004, 10:23 AM
Geistware
My Feedback: (16)
rajul, that is what I figured.
Just change the resistor in the oscillator circuit and you have a new frequency.
That is what the dials do.
Old 03-12-2004, 10:27 AM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Miles, that's my "guess" too LOL !
