Rado setup for Extra 330L
Old 03-08-2004, 01:45 AM
embpic1
embpic1's Avatar
Default Rado setup for Extra 330L
I have read lots of info here and took bits and pieces to come up with my own setup. My Hangar 9 33% 330L is powered by a 3W-75. With a 24X10 3W prop here at 2500 foot elevation is has just over a 1:1 thrust ratio. It will slowly pull out of a hover. Due to weight and balance I had to put my batteries pretty far forward. The receiver is just aft of the wings. I have the throttle servo quite close to the engine just aft of the firewall. The ignition battery is about 6 inches from the two receiver batteries. I have read quite a bit saying this is not a good idea. However this setup has absolutely had no glitches. I originally had a PCM receiver but it failed after 1 flight (sent in for repairs). All I had lying around was a PPM receiver. My PPM had the same good range check that the PCM receiver had (about 130ft). I have had no troubles with the PPM getting hits from the ignition. I plan on putting the PCM back in for the failsafe features. Looking forward to IMAC this year!
ID:	109034   Click image for larger version
ID:	109035   Click image for larger version
Old 03-09-2004, 12:22 AM
3DFanatic
Default RE: Rado setup for Extra 330L
First thing to do is put a heavier engine on there that can actually go vertical ZDZ80, DA100....
Old 03-09-2004, 12:28 AM
embpic1
embpic1's Avatar
I would love to put a bigger engine in there but money is a little tight right now. I got the 3W-75 (only one hour of run time on it) for $200 with muffler from a friend. So it will have to do for now. I think I would like to try the 3W-100 some day. So far my 3W starts real easy and runs strong.
Sean
Old 03-09-2004, 12:47 AM
Flyfalcons
Flyfalcons's Avatar
I'd say if you are range checking at a good distance then have fun! It's a great flying plane.
Old 03-09-2004, 01:07 AM
3DFanatic
Can't beat $200 if it runs well!
Old 03-09-2004, 06:43 AM
Geistware
My Feedback: (16)
The setup looks good. You could try longer standoffs, to get the engine farther out. That could help shift some of the weight forward.
Old 03-09-2004, 09:01 PM
embpic1
embpic1's Avatar
Actually the balance came out perfect. I flew it 5 times yesterday and had a blast. I did have a small problem though. On the fifth flight I noticed a few "hits". I landed it and did a range check. Well now I can't get more than about 20 feet away with the engine running before it glitches. It checks ok with the engine off. I looked it over and I think the ignition lead on the plug was a little loose. I am looking for an idea to clamp it down on the plug. Any ideas. Already thought about a small hose clamp but I don't think it will fit.
Sean
Old 03-10-2004, 12:52 AM
3DFanatic
lock tight
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
