Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > RC Radios, Transmitters, Receivers, Servos, gyros
Reload this Page >
futaba 9cap mix program for airbrake- flap and elevator
Old 03-10-2004, 12:14 PM
thornburg
thornburg's Avatar
Default futaba 9cap mix program for airbrake- flap and elevator
can soem oen help me with this setting. i tried with no luck... Futaba has treated me like was the only one on teh pl;anet with this problem.
All i want to do is asign elevator and flap to teh VRD H switch or a three pole switch and be able to adjust the amount of each control.
Why is this so hard?
Amon
Old 03-10-2004, 12:32 PM
Charlie P.
Charlie P.'s Avatar
Default RE: futaba 9cap mix program for airbrake- flap and elevator
The three position Switch C is the default airbrake switch and it would be MUCH easier to stick with that. I use that, and switch D to give elevator mixing or not (assign elevator / flap mixing to any unused mix).
Set the mode to FLAPERONS and then follow the instructions on p. 45-46 of the manual.
Old 03-10-2004, 01:25 PM
Mike Ledbetter
You can do it with PMIXes, but you will need three, one for each control surface. The first three PMIXes have all the parameters you need, unless you want exponential response from the elevator, then use the last PMIX for elevator. Note that you give up the elevator delay feature on the AIRBRAKE by not using switch "C".
Post on the manufaturer's subforum if you haven't.
Old 03-11-2004, 12:40 AM
3DFanatic
Only need two. Turn your LINK on for the flaps.
Old 03-11-2004, 01:32 AM
Geistware
My Feedback: (16)
Go to the Futaba FAQ section. They will have the answers.
www.futabarc.com
ORIGINAL: thornburg
Amon
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
