Crow on 6 channels? (JR XP662)
Old 03-12-2004, 05:32 PM
FrankC29
Default Crow on 6 channels? (JR XP662)
So, is there some sort of way of making crow work on an XP662 that anyone knows of?
Old 03-13-2004, 04:25 AM
Dauntae
Default RE: Crow on 6 channels? (JR XP662)
only way is to put a y-harness on the flaps but you will only have the ailerons on the outer section (I'm assuming this is a ultra stick) It's been a while since I used my 652 (same as 662 but a few less options) I now have a 8103 and you need 7 channels for the right setup for the crow and full length ailerons.
Dauntae
Old 03-13-2004, 10:38 AM
AMA-69405
My Feedback: (22)
AMA-69405's Avatar
Frank,
I would suggest you go to the Radio Manufacturer Support Subforum / JR Radios - Ask Danny at JR and ask the question. I could have sworn at one time there was a programming guide on the Horizon website that addressed, quite thoroughly, setting up an UltraStik with the XP662. It seems to have disappeared, but that's not too unusual for the Horizon site. I see one for the XF631 and the new XP6102, but not the XP662.
It runs in my mind that with the 662, you can have all of the UltraStik "crow" features normally available with the 7 and 8 channel radios, except one... I think it was the coupled flaps and ailerons feature (super-duper killer roll rate), but I'm not sure. In any case, Danny will be able to help you, as he writes the programming guides!
Gary L.
Old 03-13-2004, 10:51 AM
TTARK
I did this with my Ultra Stick and a Futaba 6AXS. I set the flaps up on channel 5 (gear switch), and adjusted the travel for the proper throws. You do not have full lenght ailerons, but it does work quite well if you mix elevator with channel five.
Terry
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
