Antenna routing in .46 custom plane
I have done a search for various methods of antenna routing and cannot arrive at a logical conclusion on how to eliminate that antenna "tail" hanging out the back or hung on the fin.
Wrapping the antenna in coils around a dowel or tube seems to work for some, but can some of you gurus confirm what is the very best method for these size planes. I also have 2 combat, 25 size that I would like to "fix" the antenna, if there is an acceptable solution.
I now route the antenna in small flexible tubing and let end hang out or rubber band it to the fin, some of the after market antennas would be ok, but every extra connection lessens your odds of making it back in one piece, but if that is the best solution I'll go for it. Thanks Flipstart
My Feedback: (17)
AL
RE: Antenna routing in .46 custom plane
The antenna on my Diamond Dust is totally enclosed in a piece of flexible plastic tube that makes a circular pattern through the inside of the wing. Never had any problems.
