JR 10 sx trainer?
Old 06-15-2002, 07:18 PM
I-NAV's Avatar
Default JR 10 sx trainer?
Anyone know how to make the 10sx act as the primary on a buddy box setup? I don't see anything in the manual for it.
Old 06-16-2002, 06:35 AM
My Feedback: (31)
the 10x needs to be on the same freq. as the trainers receiver.....
Old 06-16-2002, 08:51 AM
My Feedback: (62)
Default I-NAV
I have an SX for sale here if interested
http://www.rcuniverse.com/showthread...highlight=10sx]
Old 10-03-2002, 02:39 AM
I also have a 10SX and want to use as the master and another as the slave. Nothing in the manual. I will get another crystal to allow the 2 to be on the same freqency. Is there a 'switch' to toggle control?
Old 10-03-2002, 02:46 AM
The 10SX does not have a trainer switch and can not be used as the master in a master-slave setup. It can be used as the slave with another JR radio having trainer support i.e. 8103.
When used as the slave you do not turn it on and it does not transmit. Only the encoder turns on when the trainer plug is installed.
For what it's worth - Al
http://www.rchelibase.com
Old 10-03-2002, 03:45 AM
Old 10-03-2002, 08:58 AM
My Feedback: (13)
Of all the 10-series JR radios, only the 10SX II had a trainer function (Code 78) for use as a master. As stated, the 10SX works fine as a slave, although you will feel slightly ridiculous using a fancy computer radio of this caliber as a slave box...
You guys with the 10SX transmitters should troll in the scale areas. There are several scalers who fly Vario/Heim ships and need four servo/ninety degree CCPM capaility, and want a JR radio. The 10SX is the only 10-series radio that has it.
Steve
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
