hitec 555 maddness
Old 03-21-2004, 01:58 AM
thedonald
Default hitec 555 maddness
My hitec 555 receiver has been experiencing intermittent "interference" when flying this morning but I don't think it coming from another source as I experenced the same behavior much later at home. When the plane is turned on (and my 9c is on with the antenna down) the controls occasionally go crazy including the engine starting and stopping. This can also be triggered if I put any pressure on the hitec 555 case.
Bad receiver?
Old 03-21-2004, 03:46 PM
jsn
My Feedback: (8)
Default RE: hitec 555 maddness
Bad receiver....Sounds like something is loose. Anytime you can trigger a servo movement by handling the Rx it's time to send it in. just as a side note... avoid turning on your 9C or any radio with the antenna down for more than the few seconds needed to do a range check. always have either the 2 large base sections or the entire antenna up when it's on.
John
Old 03-21-2004, 04:18 PM
XJet
Banned
It sounds as if you may have a cracked PCB trace or a dry joint somewhere on the board.
Whatever the cause, don't risk flying with the receiver in that condition.
Have you crashed or droppped the receiver before?
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
