Whats good heavy duty switch harness for 25% CAP?
Old 03-23-2004, 12:43 PM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Default Whats good heavy duty switch harness for 25% CAP?
I'd like to get something a little more reliable than my usual aftermarket switch harness. My radio gear is a Futaba.
Joe
Old 03-23-2004, 01:20 PM
hilleyja
Default RE: Whats good heavy duty switch harness for 25% CAP?
After loosing 3 airplanes to suspected switch problems, I have standardized on the use of HD 2-pole switches. Most of my larger airplanes have MPI switches on them. They are more costly than OEM switches, $15.00 vs $8.00, but considering they are mounted on airplanes with investments of between $800.00 and $1700.00 they are worth the extra few dollars.
Old 03-23-2004, 01:32 PM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
ORIGINAL: hilleyja
Do you have part numbers and where to buy them? Why two poles? Reduntant batteries?
Old 03-23-2004, 05:02 PM
hilleyja
http://www.maxxprod.com/mpi/mpi-4.html#3470
SOFT MOUNT ONE-PIECE CHARGE SWITCH
3170 Futaba J switch
$15.00
3470 Hitec/JR/Airt. Z switch
$15.00
3370 Airt. w/charge adptr
$19.00
Heavy duty switch with integrated charge port and dust cover, compatible with radios with DSC functions. This switch also includes a piece of silicon rubber pad for vibration insulation.
The BEST just got BETTER!
SOFT MOUNT ONE-PIECE CHARGE SWITCH with LED VOLTAGE DISPLAY
5170 LED Switch for Futaba J
$25.00
5470 LED Switch for Hitec/JR/Airt. Z
$25.00
This switch has three LEDs - green, yellow, & red - to monitor the status of Rx pack. It is compatible with 4.8V and 6V systems.
Old 03-23-2004, 06:54 PM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Hey man, thanks a lot. That is exactly what I was looking for.
Joe
