Can you change trim without changing the end point on 9C?
Hi all:
I am having trouble with my Futaba 9C on throttle: every time I change trim, it moves the high/low ends as well.
Is there anyway to prevent moving the end points on 9C?
My Feedback: (16)
BC, CANADA
RE: Can you change trim without changing the end point on 9C?
Hi there,
Why are you having to change trim on the throttle? I own a 9C and I usually don't touch my trim tab.
You can just program a switch to be the throttle cut and you can have a switch handling a high idle setting.
The whole point of throttle trim is to adjust the low end point... But to keep it from altering the high, go to your parameters screen and turn "ATL" on. That way when the throttle gets to half-stick, trim won't change anything on it.
