servos with long extensions and y harness
PA
got two servos operating one aileron each. need 24 inch extention on each plus y harness.
when i do this one servo gets slower and sometimes does not work at all what do i need to add to
stop this prob.
stop this prob.
First you need to isolate the problem. Determine if the problem lies in the servo, in the extension or the Y harness...do this by taking them both out of the wing, plug them up and watch the movement. If one is moving a lot less then you can switch sides with the other. Then switch the servos out with other servos until you have isolated the problem...I am thinking that the problem is either a servo going bad or a nic in the wire.
