indecision on servo's...
hobbico CS-65 or the HITEC HS-625MG.
here in israel it's the same cost plus minus...
it's going to sfly on GSP/ CM PRO Katana 72" with MOKI 180 .
so what servo is prefer?
thanx alot!.
Werinstock.
thanx alot!.
Werinstock.
RE: indecision on servo's...
yeah...
in the site of Hobbico wrote "resin / metal"...
i dont know what is it' what about the futaba 3305? it's the same liege?
10x.
10x.
ORIGINAL: DownSideUp
I don't think the Hobbico C-65 has Metal gears. I would go with the Hitec servos. I have some of those and they work fine.
oh, OK.
so the best is the HITEC HS625MG?
ORIGINAL: Sport_Pilot
That usually means that the final gears, the ones that usually strip, are metal but the pinion and other fine gears are plastic.
exact servo?
how?, they have a different specs:
HS625MG:
Speed- 0.18sec/60 degrees at 4.8V
0.15sec/60 degrees at 6.0V
Torque-76.37 oz/in at 4.8V
94.43 oz/in at 6.0V
and that a have all metal gear...
CS-65:
Speed- 0.16sec/60 degrees at 4.8V
0.13sec/60 degrees at 6.0V
Torque-77.00 oz/in at 4.8V
92.00 oz/in at 6.0V
here the gear are metal and resin (plastic).
HS625MG:
94.43 oz/in at 6.0V
CS-65:
92.00 oz/in at 6.0V
ORIGINAL: shortman
They are the same exact servo, just remove the hobbico sticker and you will see.
My Feedback: (21)
Every metal geared servo has one nylon gear, thats the B1 gear I believe, its the tiny little gear at the bottom of a servo which for some reason.
If the prices are the same go with Hitec, but there are not that many servo companies out there, just different labels.
ok.
thank u all very much i go with the HITEC.
Gal.
Gal.
ORIGINAL: shortman
