JR 10X help
My Feedback: (69)
AR
JR 10X help
Have a question for the 10X gurus. I am running split elevators in my 90 funtana and one servo is a tad slower than the other. I am using a y harness. (Hitec digital servos programmed and reversed to mach), I know you can use 2 separate channels for the elevator, but that is ch 2 and aux 3, which is ch 8. My issue is I am using a 7 channel rx, so how do I program the 10X to run on 2 channels with only a 7ch rx? I currently have ch1 on throttle, 2-ailerons, 3 ele, 4 rud, 5 open, 6 aileron 2, 7 open and then the battery, any info would be great.
