digital trims
digital trims
i have a question to ask about digital trims. When i am triming my model out with digital trims will it save it to the model memory, becasue when i move the trims on the radio i have at the moment, which doesnt have digiatl trims it leaves the nest model i choose untrimed agian, so it leaves me to trim the model again.
thanks, i hope it makes sence.
My Feedback: (27)
RE: digital trims
It saves your trim settings every time you turn it off. If you change to a different model, the trim settings will be the same as the last time you flew that model. I couldn't imagine going back to mechanical trims again.
My Feedback: (9)
FL
RE: digital trims
On Multiplex Profi 4000, it has manual trims, but when you power up the radio, the trim settings are noted from the last time you used it, and if they are in the wrong place, little arrows show up to tell you to move the trim levers back to where they should be...too cool..
My Feedback: (36)
RE: digital trims
RE: digital trims
thanks for all you replys, to answer your question Bob_nj, my transmiter at the moment is a JR F500, with two model memory, anolouge trims, which can be frustrating when changing model.
