Antenna Strain Relief - Do they work???
What's up with the antenna strain reliefs that are often recommended in the instruction manual? Do they work or is it a conspiracy to get us to chop up servo arms and buy even more? I don't know if this has ever happened to anyone but the last time I had a crash, the receiver was forced all the way backwards by the impact. And guess what? The nice little antenna strain relief I had just outside the hole in my fuselage actually prevented the receiver from moving backwards so the whole receiver was ripped open by its cord. Lucky it wasn't "hurt" apart from having its "clothes" torn off... Maybe it would have suffered more had I not have this strain relief. Maybe the wire would have been chewed off by the prop...
RE: Antenna Strain Relief - Do they work???
They're not intended to help in a crash. Most of the time nothing helps there. They're intended to relieve the strain on the antenna as it exits the receiver. This is to prevent failure over the long term since nothing is pulling on the antenna connection inside of the receiver.
Edit for clarity.
Edit for clarity.
In most of my crashes, the number which I choose to keep a secret, the only times the RX antenna was pulled apart was when I had the antenna taped to the fuse or otherwise "hardwired". Never had the problem when, I've attached the end to the rudder, or bottom end of the fuse with a rubber band. The band either breaks or is thrown off, thereby giving the antenna room to move with the RX. Of course your milage may vary depending on the circumstances of a particular crash
My Feedback: (48)
MI
You had the strain/relief on the OUTSIDE of the antenna exit hole?---
ORIGINAL: MeanMustang
I usually wind up cutting excess arms off of servo arms anway, but I've also used buttons and other things to do the job. It's not really important what you use, but you should use something.
