28% EDGE 540T 3 hours flight time
WI
I was wondering if any of you here has any Ideas on how to make a plane like this fly all day without any troubles Im thinking my best bet might be a good field charger. Is a PCM radio a must? Are computer servos a must? can you get the same speed and accuracy with more reasonable priced servo than a JR 8611 It is begining to look like taking a plane like this to the field and putting it in the air all day is a insermountable task
My Feedback: (27)
CA
RE: 28% EDGE 540T 3 hours flight time
Try dual Nimh 2400Mah batterys each with their own switch and use a diesel conversion.
The Super Thunder Tigre 4500 with a Davis head should work pretty well.
With this set up you should be able to use any servo you want.
My Feedback: (23)
ORIGINAL: bluemagic98
...Im thinking my best bet might be a good field charger...
Dual batteries packs on separate switch circuits are still a good idea for redundancy, when you get above ~28% scale. But the focus should be on max peak current delivery, not max capacity. You can use smaller capacity 2/3A cells, which typically have a higher current rating than AA cells.
WI
Ralph you misunderstood i dont want it air born for 3 hours just a total time between charges Volfly has the right idea ive been ussing my cub a lot its a 81 inch great planes with a stock battery in it and i re charge that at the field I worry about that plane and am considerinf a 1400 mah pack for that I feel fast charging at the field is a bad idea on a continuing bassis. so i may be looking for a good cycling charger for the home do they make one that has 12v field inputs and can do a faster charge at the field? As for my new project i was looking at 3 2200mah li-poly with regulators and failsafe switches from fromeco and your right batteries wiring and charger is over $300 add a few high end servos and a pcm reciever if i go that rout? and i have about $1000 in wirring then add a transmiter? this may or may not go this way this is the high end opptions for me. still looking at a cheeper setup and a good field charger would be part of that.
My Feedback: (46)
NJ
Check out Central Hobbies. They are having a special on NMP Li-Ion battery and charger combo.
http://www.centralhobbies.com/Special/today.html
I have been using these in my pattern planes with 6 digital servos all the way around. (5.7 V Voltage regulator of course). I can easily get in 6 flights without charging between flights.
My Feedback: (23)
I have two Triton chargers at home for cycling and conditioning all my battery packs. This is the charger I bring to the field:
http://www2.towerhobbies.com/cgi-bin...?&I=LXCTZ5&P=0
I use it to top off everything from flight (6V), gas ignition (4.8V) to onboard glow driver (1.2V) batteries. It will also do TX, though I find that rarely necessary with a 1600mAh pack in the 9C.
Regardless of what type battery and what configuration (dual circuit, regulator, etc.) you choose, a good field charger is excellent insurance against arguable the #1 cause of RC crashes - loss of power.
