Digital Servos - PCM required??
My Feedback: (16)
ND
I have recently been upgrading (well adding to) my radio equipment and decided to give the PCM/Digital side of things a whirl. I know very little about this PCM/Digital tech.
I just received my new Futaba 7CHP and got to wondering about these digital servos. I know the 3151's that came with the radio are the low end of digital servos but I put a S9253 in the tail and I must say impressive!
I am fully aware of the PPM vs PCM debates which is part of the reason I decided I needed to take the plunge and try PCM and decide for my self what, if anything, is really gained.
My question is this:
Do you need a PCM Rx to use digital servos? I understand that this Rx with PCM 1024 has higher resolution than the older PPM systems, correct? The real question is if I ditch the 3151's for something better can I use them in one of my older PPM systems? What do I loose by doing so? Anything?
A little clueless...?
Riff
Riff
My Feedback: (16)
ND
RE: Digital Servos - PCM required??
Ah, I just notice that the 7CH (PPM) vesion ships with the S3151's as well, so I am assuming that means I can use digital servo's on standard PPM RX's?
Digital servos do not require PCM or even regular old FM/PPM. AM will work fine. The sevros don't care how the signal gets to the RX.
AZ
ORIGINAL: RiffRaff
Riff
Riff
My Feedback: (16)
ND
So essentially there is no difference between a PPM vs PCM RX in terms of the sevo capability?
Well, other that the fact that PCM is a discrete 1024 digital steps versus the thoretically infinite resolution of analog PPM?
Thanks all!
Riff
Thanks all!
Riff
AZ
ORIGINAL: DadsToysBG
Some of the new digs have a 5800 step whether you use PCM or PPM. Bytheway PPM on stock are 512 coreless with PCM are 1024. Dennis
