Magnets and receivers? HELP
CA
Will a small magnet about 6" away from a receiver antenna cause any trouble? it would be a weak magnet, like that flexible rubbery stuff that you use for refrigerator magnets. Would that cause any trouble?
CA
RE: Magnets and receivers? HELP
Probably not. If you were talking about a magnet right on the receiver, it would be another story. A magnetic field close (in contact with) to a receiver would change how any of the inductive components in the receiver would work.
Absolutely no effect, even if sat right on the reciever. The only way it would effect the radio would be to have it moving relative to the radio at a very high frequency like thousands of cycles per second and even then it would be doubtful.
CA
Even a static magnet field will affect an inductor. The field moves the inductor closer to magnetic saturation (or further away depending on field polarity). However, in either case, it can influence the frequency resonance of an LC circuit. At least that what my EE professor said back in 1972. I don't think physics has changed since then. I have seen a practical demo of this on an FM box destined for a satellite. The box would quit working when the EM field of the shake table was powered up, before the shaking started. We had to solve that one by mounting the box on a long standoff to get it out of the magnetic field. The shake test was to see if the FM box would survive a rocket flight.
Banned
But the coils in a receiver operate *so far* away from the saturation point that even an extremely strong magnet would have no perceptable effect.
Wisdom-seeker, there is a big difference between an electomagnetic field and a magnetic field.
with some 40+ years experience in instumentaion, RF, and guidance systems, I can still assure Spaceclam that NO EFFECT will occur with the magnet right on his receiver case. Yes shakers do create an interferance problem if every thing is not set up properly but that was not Spaceclams question.
AZ
ORIGINAL: Rodney
I am curious, though, as to the difference between an electromagnetic field an a magnetic field. Please explain. All of this time since I graduated from E.E. college I thought they were the same.
TN
Dirtybird,
Apparently Rodney went to school before the GUT. Or he's talking about an AC mag field (as with a shaker motor) vs. a fixed mag field. Now do you know the difference between the weak force and the strong force?
ME
Well, a static magnetic field has only a B vector present, and an electromagnetic field has B and E vectors at 90 degress to each other. Anything else will not propagate. They don't teach this in EE, you have to take Electrodynamics in a Physics course to get this type of abuse.[&:]
Steve
Steve
AZ
ORIGINAL: RunningMan
Steve
Steve
NY
ORIGINAL: Rodney
Absolutely no effect, even if sat right on the receiver. The only way it would effect the radio would be to have it moving relative to the radio at a very high frequency like thousands of cycles per second and even then it would be doubtful.
And; RunningMan,
I don't know who the EE's are that you might know, but the relationship between magnetic and electric fields was basic field theory in my EE curriculum - and that was 39 years ago!
