JR R600 Receiver Crystal Swaps--Any Problems?
Got a JR R600 6 channel 72MHz receiver that was on channel 49. I swapped crystals to match my JR X-388S transmitter's crystal. Any problems with that swap? Thank you. (My first JR radio! I know some Futabas have high/low ranges. I've heard that you must send back to factory for retuning if you switch some channels. Is this fact or fiction?)
CA
JR "center tunes." Just install the new Rx xtal, range test, then fly.
Fact. Perhaps not needed if you can live with the reduced range due to a high/low band swap.
