9303 Help!
NC
9303 Help!
i dont really get is the left and right aileron adjustment that you have on both the left and right adjust modes Left ail: adj L adj R right ail: Adj L adj R
Help!
Help!
RE: 9303 Help!
I assume you are using the acro mode and have wing type set up as flapperon and that you are letting the radio do the mixing for both channels and not trying to do the mix yourself. Set this way when I bring up the travel adjustment screen for RAIL I get L 100% R 100% and for LAIL I get +100% -100%. This is simply setting the throw for each aileron.
OR are you using glider mode with a dual flap setup?
Ed M.
Ed M.
