Futaba S-9303 question-? problem?
Hi all,I just read a thread re.Futaba S-9202 servo buzz. I have Futaba S-9303 servos.I assumn that the buzz noise in these is the same as in the 9202's.?? Here is what happens when I cycle mine on a servo "exerciser".Two of the servos will cycle then start moving back and forth in short jerky motions,the other 3 hesitate,during the cycling, momentarily now and then ,along with the buzzing noise.Is there some type of cleaning or maitenance I could do ,rather than sending them back for servicing??? These are coreless,metal gear servos. Thank you...Bob R
