Hitec 5995/5955 issues
Old 07-28-2005, 01:07 PM
mglavin
My Feedback: (31)
Default RE: Hitec 5995/5955 issues
How many regulators for flight system, one for each battery? How many switches for the flight system, one for each battery?
It's irrelevant but who offers 2350mAh lithium-ion flight packs?
Sounds like the servo is damaged, I'd suggest returning all the servos to Hitec Service for post crash inspection.
Old 07-28-2005, 04:02 PM
Kougar IV
One regulators for each battery
One switches for each battery
http://www.troybuiltmodels.com/LiIonBatteries.htm
with The Smart-Fly BatShare
Old 08-17-2005, 05:46 PM
mrbigg
My Feedback: (21)
mrbigg's Avatar
are these back on the shelves, ready to sell?
Old 08-18-2005, 12:31 PM
MikeMayberry
MikeMayberry's Avatar
Yes. The current 5955's have no known issues. Any older servos can also be sent to Hitec to be updated.
Mike.
Old 08-18-2005, 12:39 PM
Forgues Research
My Feedback: (7)
Forgues Research's Avatar
ORIGINAL: MikeMayberry
Mike.
Hi Mike,
I have 6 of the 5995's in my 52% Edge which will fly later this year, but before I do, any know issues with these and what is the best thing to keep them from failing , voltage etc....
Roger
Old 08-18-2005, 03:54 PM
  #31
mrbigg
My Feedback: (21)
mrbigg's Avatar
thanks, Mike.
Old 08-18-2005, 05:52 PM
  #32
MikeMayberry
Aerographixs- Just make sure to provide them with plenty of power. Each servo is capable of pulling up to 3A under stall conditions.
Mike.
Old 08-18-2005, 09:25 PM
  #33
Forgues Research
My Feedback: (7)
Mike.
Thanks Mike, will do.
Roger
Old 09-26-2005, 03:24 AM
  #34
ashkanani
ashkanani's Avatar
HI Mike..
just wondering.... now with the new programer update V1.04 is it possible to edit and program the 5995TG servo's...
Abraham
Old 09-26-2005, 10:00 AM
  #35
mglavin
My Feedback: (31)
ORIGINAL: ashkanani
HI Mike..
Abraham
Yes, that was the specific purpose of the latest update.
Old 09-27-2005, 04:49 PM
  #36
ashkanani
ashkanani's Avatar
Thanks mglavin for the good news...
Abraham
Old 10-02-2005, 11:15 AM
  #37
Modified
Modified's Avatar
I've got 5 5955/v1.04 going in a 34% extra that should be ready in a couple of weeks, I am going to run them straight out of the box and I've read somewhere that there are problems with the v1.04. Anybody else having problems with these?
Old 10-02-2005, 11:38 AM
  #38
mglavin
My Feedback: (31)
There are NO problems with the servos unless you want to drive two with a wye and a single channel source using Futaba PCM... In this scenario the Futaba RX is unable to provide adequate sink current to drive two servo form a single channel. Hitec realized the shortcoming and later updated components to accommodate the use with multiples and Futaba PCM. While the servos will work fine out of the box, if you feel the need Hitec Service will update the servos free of charge.
Old 10-02-2005, 11:49 AM
  #39
Modified
Modified's Avatar
I just bought these this week from Don's hobbies in Paris Tx. I will try to send them in this week. Would there be any problemwith current draw running 5 5955's thru a Hitec HFD-08RD Supreme Rec.
Old 10-02-2005, 11:59 AM
  #40
mglavin
My Feedback: (31)
Is there a trash can symbol with a line through it on the servos? If so, no need to update them.
If your using the Hitec RX there is no need to update them, however its your call. The problem noted previously is specific to Futaba PCM RX's only.
Yes the Hitec HFD-08RD will work fine with 5-5955TG's. Be sure and use HD swithces and wiring components with gold plated connectors and a robust power source. At least a 1950mAh five cell; high discharge capable batteries are desired.
Old 10-02-2005, 01:09 PM
  #41
Modified
Modified's Avatar
I was thinking about the Thunder Power pro lite 2cell 2100 mAh li-po (15c cont, 20c burst). I was going to run two on the reciever thru HD switchs and 6V regulators.
Old 11-03-2005, 04:51 PM
  #42
Buzz Lightyear
Hi Mglavin
Does running multiple 5995's through a matchbox with a separate battery fix the problem?
Cheers
Buzz
ORIGINAL: mglavin
Old 11-03-2005, 07:22 PM
  #43
mglavin
My Feedback: (31)
Buzz
As far as I know yes. I have not personally tested the combination with a Matchbox. Any product that isolates the servos from the Rx is said to eliminate the problem associated with Futaba PCM Rx's.
Old 11-03-2005, 09:35 PM
  #44
NdFrSpeed
Not to mention any names but somebodys not being real honest here,,ive went through 12 HS 5955's to get 8 to work right,,send them back sure enough,,they relace it,,but there are problems with them,,no doubt in my mind,,early in the thread,,someone had a rudder go full over,,i know somebody thats lost 2 35% Extra's,,same reason,,but it was on the ailirons instead,,,you check some of these on the new verison programmer,,you hook them up and they go into some kind of test mode by themeselves,,,then they stop,,you reach over and just touch the arm and the servo takes off again doing all kinds of crazy stuff,,so beware,,im talking about servos in the last 30 days that ive gotten.Had one on the elavator,,just go nuts,,flipping from full up full down and every where in between,,brand new right out of the box,,throughly test before useing is my advice,,
NdFrSpeed
Old 07-24-2007, 05:55 PM
  #45
raubold
My Feedback: (156)
Hi Michael
I am running 3 5985s on Singel impulse from a Futaba 148 PCM and had no problems so far. Power is suplied over singel Pos and Neg with Ultra Deans Conector to Each servo seperat.
Do You think there could be a problem down the Flightline please let me know. Dont want to loose my AW 42% 260
Thanks Michael Raubold
Old 07-24-2007, 06:16 PM
  #46
mglavin
My Feedback: (31)
Michael,
You should be OK, the initial problem with the minimal sync current experienced with Futaba PCM RX's has been worked through.
What surface are driving three servos with a single control signal and how are the servos inter-connected?
Old 07-26-2007, 09:44 AM
  #47
raubold
My Feedback: (156)
Running the Ailerons with 5985s on my Extra 260 from Aeroworks, programmed to use without Matchbox. Draw on Zero is about 35 ma and full deflestion is under 300 ma without Load. The two 5955s on the Rudder about 1 amp full deflection fighting the Tailweel springs, witch i fix with softer Springs. Elevators programmed for no Mathbox use goes about full deflection 120 ma no load. I am running all Servo singel impulse from two Receivers (148 PCM) exept the Ailerons with 3 5885s on Ailerons and had no problems so far
Thanks for reply Michel
Michael Raubold
Old 07-26-2007, 09:59 AM
  #48
raubold
My Feedback: (156)
Forgot Servo Power conected thru Ultra Deans for Power and singel impulse from Receivers to each Servo in Wings with singel Wire
3 inch long Y-Conector ( Home made). Made shure that I have no Loops in Negative or Positive wiering witch can cause most of the
problems with Digital Servos in my experiance in electro-techiqe. I use to work in Audio and Studio electronics an know about wiering
and inductions into wieres if you run closed ground or supply loops. I also used Oscilloscope on the wiering to make shure that there is no unwanted impulse induction from one wire to annotherand came out clean.
Michael raubold
