JR Xmtrs
JR Xmtrs
Recently, I inherited two JR receivers-a PCM 10(NER-910xz) , 10 channel and a 9 channel FM NER-529x.(Both 72mhz)
Knowing little or nothing about JR equipment, could anyone take the time to recommend a transmitter (JR) and pertinent info as to approx age (date of issue, etc.).
Any other comments about suitability for todays sport planes and these radios would be greatly apprecited.
Thanks, Soarbeit
Thanks, Soarbeit
My Feedback: (506)
JR Xmtrs
The NER-910xz is a 10-channel, single conversion (ABC&W) Z-PCM receiver. This is the rx that was supplied with the top-of-the-line JR radios back in the day, so quality is excellent. Its a heavy bugger, though.
Z-PCM is JR's 'old' 512-bit PCM scheme - you'll need a computer TX that supports this. Good news here - all the current JR radios from the 652/662 on up support this modulation type. Most of the older 7-channel+ JR radios support this modulation, too. (Like the 347, 388, 8103)
The NER-529x is a 9-channel, single conversion (ABC&W) FM receiver. Any radio that can drive the previous receiver will run this one just fine.
Both receivers use standard JR 'grey cap' crystals.
