Reciever Connections
IN
When using any given radio with any number of channels.....Can the RX batteries be plugged into any availiable slot beyond the number of channels the radio is capable of? For Example I have a Hitec Eclipse 7. If I use a 9 channel reciever and 7 channels are taken by functions of the given aircraft, can slots 8 & 9(or which ever is free) on the reciever be used for RX battery packs? Or does the number of channels the radio has dictate the total number of slots used on the reciever, even if the excess channel is only going to be use for RX battery
Thanks in advance.
Thanks in advance.
IL
RE: Reciever Connections
Any port open will work for the battery. If you're using all ports & have none open for battery you could put a Y cable into one of the ports & connect the servo & battery into the Y. I've done this on a couple of my planes & for some reason I'm more comfortable putting the Y on the throttle channel.
