hitec spectra module
OK
If I am at the flying field and I remove the Spectra Module from the back of the transmitter can I saftly turn on the transmitter without worrying about whos on what channel? The reason I ask is I may want to check which channel a certain plane is on before I change my tag on the board.
Scott
Scott
RE: hitec spectra module
Yes this is the proper procedure to do that. Without the module no signal can be radiated and it will not harm the Tx.
Its also good practice to do this while programing the radio which negates the need to partially extend the antenna to avoid overheating the RF output section with a collapsed antenna.
John
John
